MK3 Fezz Turbs lower arms
Just changed my lower arms ( failed MOT on rubbers , normal ) done the offside no problem
Then went to fit the nearside and the ball joint doesnt go all the way through the bottom of the hub so the pinch bold can go through, deplhi by the way ,
i even droped th ewhole weight of the car onto it and no luck at all
Measured the old one versus the new ones and the ball joint pin is 2/3 mm wider under the pinch bolt channel or just above the ball joint grease cap
has anyone had this before
and yes before u ask i have tried knocking shit out of my hub to widen the gap for it to fit up into but no luck
ill have to take it back 2 mozz so they can order a new one
FFS !!
FFS !!
cheers for help lads ! FFS
After alot of fucking around found out my nearside hub is off an xr2i and the ball joint hole at the bottom is a different size to match the different size ball joint
THAT IS ALL
THAT IS ALL
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
Steve Escos
01-10-2015 06:57 AM
