Mondeo mk3 bad brakes
Hi my 2003 mondeo tdci has terrible brakes. I bought the car with the abs light on and the brakes seemed ok. I fitted a new abs sensor and cleared the fault code and now my pedal is hitting the floor and is very spongy.
I'm pretty sure its coincidental though.
The car has good discs and pads and no leaks on the brake lines that I have seen.
I pressure bled them twice and its made only a slight improvement and somtimes the pedal feels ok and others very soft.
Any ideas what's going on?
Spelling Club King!
If the pedal is sometimes hard, and sometimes soft it may be nothing to do with the brakes as such.
Take the wheel off and see if the hub nut is tight. If it's not, then tighten it (280Nm I think) if it comes loose again you need to replace the hub flange otherwise it will keep happening, and also start to take out wheel bearings with it.
I'm also getting a wheel bearing failure noise. Went round the wheels today and wobbled them but felt nothing.
I also pulled all the wheels off and made sure the pads were sitting flush on the disc and not caught on any lips.
Could the wheel bearing noise be the hub nut coming loose?
EDIT
Just checked the fronts and they are both properly tight. Can't do the rears yet as the dust covers were hiding the nuts.
EDIT
Spelling Club King!
EDIT
EDIT
If the brakes are depressed it pushes the pads together and takes up the 'slack' caused by the worn flange. Hence why the brakes sometimes feel fine, and at other times very soft with a very long pedal.
I did try that but failed to notice any play, but the noise is loud and certainly points to a failed bearing and the pedal is not right.
I will remove the rear wheels and dust covers tomorrow and check they are tight.
I spun all 4 wheels as well whist the car was jacked up but I failed to notice a difference in any of them by sound or feel.
Thanks for all the help so far, I appreciate your efforts in helping me here.
Spelling Club King!
I shall try and do it tonight if I get time.
There is a horrible hum coming from somewhere.
I will check google now on what's involved with a bearing swap as well.
I shall report back if I find any play
Spelling Club King!
But be careful that it is just a bearing and not a flange too - I replaced one of the bearings twice before realising that the flange was worn, so ended up doing the job three times in a month!
I have access to a few presses through friends.
I've got a starter motor going on today then fingers crossed I can sort the bearing noise.
I should have know not to buy a car that's been chopped in on part x
Okay so the starter is now fixed.
On the brakes we jacked up each wheel and couldn't find any play or hear any noise to give us a clue to what bearing is faulty.
But when I drive there is a loud and distinct rotational rubbing noise.
Also on the brakes I was advised it was air in the lines despite my pressure bleeding, he said it may be stuck in the abs pump, so he took my car on a loose surface and was hitting the brakes hard and he claims that will push air out of the abs pump when the abs system starts working hard?
i was advised that I should now pressure bleed it again to remove what air has moved from the pump to the lines.
The brakes are better than they were when I started the thread but still not great and the horrible bearing noise is still there.
I'm baffled on it.
I'm baffled on it.
Dr. Ickxs
15-09-2015 10:15 PM
