my new porsche brembo rear brake upgrade, pics added
I have just finished my rear brake upgrade. Using Porsche 944/968 front brembo calipers and focus rs front discs. The calipers have a mounting hole measurement of 94mm and the hub carrier is 90mm. So the holes on the caliper were drilled out to suit, 2mm inwards on each one. The bolt holes on the hub carrier were drilled out to m12 to match the calipers. Offset adjustment was sorted by machining 3-4 mm of the inside of the caliper mounting lugs. As for the disc size the diameter was reduced from 324mm to 314mm by machining, this allows the caliper to bolt right on without altering the hubs or making brackets.
Not sure if this has been done before but it has turned out well, I'm pleased with it!
http://i614.photobucket.com/albums/t...g?t=1365614440
http://i614.photobucket.com/albums/t...g?t=1365614479
http://i614.photobucket.com/albums/t...g?t=1365614511
track.focus'd
12-08-2015 05:53 PM
