15" wheels and ST170 brakes
02-04-2013, 10:57 PM
Anyone know of any 15" wheels that'll fit over ST170 brakes?
03-04-2013, 06:27 AM
Moderator
bit of a strange request as 15" will look like matchbox wheels in those huge arches, as 17s were std
03-04-2013, 08:44 AM
They're for fitting snow tyres a couple of weeks a year and it's not an ST170.
03-04-2013, 10:22 AM
I've seen it done on a Fiesta zetec s (with standard 15" wheels) but it needed angle grinding to the caliper...Something I'm not prepared to do.
06-04-2013, 07:51 PM
06-04-2013, 07:53 PM
Ben
You'll need to grind some clearence on the carriers regardless of what 15" wheels you fit unless they have a daft offset.
06-04-2013, 09:36 PM
Compomotive CXR's will 15x7 ET35 clear with tons of room
06-04-2013, 10:08 PM
Most aftermarket 15s will fit no mods need on stock off set.
07-04-2013, 07:46 AM
Thanks people, much appreciated, any more suggestions also welcome.
07-04-2013, 11:12 AM
Pro race, comp's, oz, dezet, fox, speedline, wolf, tsw.
All of these make wheels will clear st setup.
07-04-2013, 05:31 PM
Far as I know it's Only Motorsport wheels that will clear, i tried a few after market ones and they didn't clear. I'm not sure if pro race 1.2's will clear the guy that I got the CXR's from said that won't
07-04-2013, 08:08 PM
Quote:
Originally Posted by
JOHNDQ
Ive made a video on tube showing that 15inch pro race wheels fly over St170 brakes.
07-04-2013, 08:26 PM
Spanner monkey
Speedline corse do, with 6 pot calipers also
07-04-2013, 08:32 PM
What Caliper is that ive ordered a HiSpec 300mmx28mm race kit with there R126-6 6pot race caliper for my RS2000 using the Compomotives
08-04-2013, 06:54 PM
Spanner monkey
They are the monster 6 calipers with the st170 disc.
08-04-2013, 06:56 PM
Spanner monkey
Its the monster 6 caliper with st170 discs!
my wheels are 7X15 Et33
08-04-2013, 07:32 PM
Looks good my Comp's are 7x15 et35 but the discs will be 300x28mm
08-04-2013, 07:39 PM
Gadget
Spacers?
08-04-2013, 07:43 PM
Spanner monkey
Straight_4_N/a
Spacers?
No mate, nothing, although i will probably run a 5mm spacer for more tyre / shock clearance
08-04-2013, 07:46 PM
Gadget
=) im upgrading to 6 pots then, I knew 4 pots would fit but thought 6 would be to big under 15s.
28-11-2017, 09:35 PM
Gadget
what hispec part number is the caliper bracket
i have some hispec billet 4s and would like to run them on a st170 disc behind 15" wheels
original
30-01-2022 08:20 PM
JK12
33
26-04-2021 12:09 PM
saul1988
Wheels and Tyres
24-08-2015 06:42 AM
borboyous
22-08-2015 11:17 AM
track.focus'd
12-08-2015 05:53 PM
15 ,
170 ,
brakes ,
corse ,
focus ,
inch ,
motorsport ,
rep ,
speedline ,
st ,
st170 ,
wheels
