2002 Escort Van heater only blowing cold air
Old 29-03-2013, 05:39 PM
Vinny69
Vinny69's Avatar
Default 2002 Escort Van heater only blowing cold air
Hi I have just bought a 02 plate escort van but the heater does not seem to get warm - It only blows out cold (or at least very very very luke warm) air; anyone got any ideas?
I am ok with taking things apart so would have a go at it myself. I have done a bit of searching on the web and heard it could be the heater valve or maybe the matrix?
Can anone offer any suggestions or had a similar problem. The van has done high milage 148k not sure if that makes any difference?
Any help would be great.
Thanks
Vinny69
Old 19-11-2013, 01:51 PM
Diesel combi pete
Diesel combi pete's Avatar
Thanks
Vinny69
Has any one out there got a clue I have the same at the moment i have today flushed out the matrix and it is clear but still not getting much heat out of heater.
This post mentioned a heater valve > I did not think there is one on the escort mk5 is there? Any other help would be great thermostate seems okay too. any help well welcome cheers, Pete
Old 19-11-2013, 07:58 PM
cabriolet
cabriolet's Avatar
not got a heater valve remove a heater pipe see if you have any flow with the engine running fill the heater pipes up before you fit them to stop airlocks if this all fails waterpump would be my guess
Old 19-11-2013, 09:04 PM
DangerousBryan
DangerousBryan's Avatar
Its usually the oil cooler that blocks up. Try bypassing it to see if your heater improves. Its the bit that the oil filter gos onto.
Old 20-11-2013, 07:28 PM
Diesel combi pete
Default thanks
I will do that, I was thinking if I take the outlet pipe from the matrix off and run the engine, I should see then if I have any flow. Fingers crossed. Cheers, Pete
Old 20-11-2013, 07:29 PM
Diesel combi pete
Default cheers
I will check that if it looks like it can be byepassed i will do that and see what hapends Thanks, Pete
Vincereese
01-06-2023 09:14 AM
FlashRS
14-09-2015 12:36 PM
Mxkid
31-08-2015 10:02 PM
Vincereese
18-08-2015 03:57 PM
Vincereese
16-08-2015 06:38 PM
Quick Reply: 2002 Escort Van heater only blowing cold air
