xr 130 Lambda sensor question
Hello
Im fitting escort 130 HO inlet and ecu etc to my black top zetec.
I have made a rwd exhaulst manifold and need to know how far into the manifold the Lambda sensor should go.
I have bought new lambda sensor ( correct one for the escort) and welded a 10mm boss to the pipe but it looks like the might sticking to far into the pipe.
Does anyone know how big the boss is on the original manifold or know if its just the tip that needs to be in the manifold.
Many thanks Paul.
Many thanks Paul.
Si B
12-09-2015 06:49 AM
