Starting a car after 10 years?
Sorry its not a ford
I've acquired a ST185 Celia that has stood for 10 years, and hasn't been started in around 5
I had to save it.
Any advice or tips before I try to start it up?
check/change plugs
check/change oil
new fuel
make sure there's nothing living in the induction system and give her a whirl?
Any advice appreciated
Regards
Dean
I had to save it.
check/change plugs
check/change oil
new fuel
Regards
Dean
struggling with reality
First of all replace the Oil and filter if you can, check levels on other fluids.
if you can warm the bottom of the engine for a while with a radiant heater (no more than 1kw or you can melt stuff) to get the sump and oil it contains nice and warm. then disconnect the coil pack(s) and crank, this gets the oil partially circulating.
then you can go for it! fingers crossed. you might want to check the cam belt of the engine has one!
Best of luck
one last thing brake fluid will need replacing if you want to stop after going!
Best of luck
do this ^^ the only thing Id add is plugs out an turn by hand a few time just to see if things may be locked up like the rings ,if good just crank as is an if you can look into the rocker box to see that oil has made it to the top if all good plugs in an fire away!
rog
04-09-2015 12:10 PM
Archiejay
12-08-2015 12:07 PM
Red_bull
09-08-2015 08:34 AM
sridgett
15
03-08-2015 07:26 PM
