Attaching body panels/trims/arches etc
Any body shop guys please
3m double sided trim tape has been suggested for wheel arch attachment of std factory bits, is it 6mm or 10 mm
Agree with Tiger even one day you will be able to get them of mate if you go steady, or silicon as gash as it sounds it good................ please it is better than it sounds lol
rob dont use tiger seal, you'll damge the panels trying to take the moulds of again, i use 3m tape best tape you'll ever get, http://www.spraygunsdirect.co.uk/pro...oducts_id=6847
+1 for 3m tape. as long as you degrease your trims and panels then warm slightly its great stuff . I use it all the time in work . i belive it was the 6mm thickness on arches from factory .
mk3ste
17-10-2021 10:09 AM
