P1518 Checking IMRC on ST170
Hello, sorry if this question has been asked before but I am new here and to the hole forum stuff.
I'm getting the common P1518 on my ST170 and after doing some searching on the internet and will be taking off the IMRC box and checking the normal faults.
The thing I would like to know is where does the cable from the IMRC box connect to?? I've tried tracing it and it seems to go under the airbox then disappears but cannot find where it connects to.
Does it connect to the inlet manifold on the left or the right side of the engine?? Also is it possible to see where this cable connects and see if it moves when the IMRC kicks in?
Thank you for your help in advance.
