how to identify
how to identify
getting a gear box tomorow. how do i identyfy it as a series 2 erst gear box?
number to look for or something?
how much they worth as well?
you cant tell the difference between any other escort box cvh boxes all look the same
the only difference is that the RS BOX AS GOT A LSD but you will only know that when its in your car (unless the drive shafts are with the box that way you will know if its got a LSD as both drive shafts will turn at the same time) money wise anything from if its a genuine rs box anything say from
£75.00 to £150.00
£75.00 to £150.00
Thats not 100% true, If the box has no shafts you can still identify if it has a LSD, if you look through the hole where the shafts sit you can see a bar going across the hole in a none lsd box, if it has the lsd then the hole is empty.
sorry mete yes your right i for got about that way
Gra
12
06-01-2005 09:45 AM
the strut brace
17-10-2004 08:39 AM
