Ford Focus ST170 Isofix solution.
Help please, looking for a bracket or a kit so that i can use an Isofix child seat in the back of my ST170.
I have contacted Ford and they said that there isn't one available.
Does anyone know where i could possible buy a retrofit one or if there is a non genuine one out there to buy.
Thanks
Thanks
It's not in the list of compatible cars but i guess it may fit.
I did see this one and contacted the seller but he never got back to me. Also it says its for 2005 - 2010 and mines a 2003.
would this work http://www.ebay.co.uk/itm/Ford-Focus...item20ce9e454b
'I can only say it may fit but you might find the factory pre drilled and taped fixing points are not present on your cars floor plan and would therefore need to be retro fitted'
Any ideas if this can be done and would i need to drill holes to fit them?
Had a look under the seats and found 2 holes with blanking grommets in them. Are these the ones used to fix the Isofix bracket? They seem to be a bit further back than i thought they would be.
Also only found these holes under the rear drivers side only. Does anyone know what size bolts would fit? Thanks
I can confirm that a Mk2 Isofix bracket fitted my ST170. Just check under the rear seat behind the driver for 2 holes with blanking plugs.
This was very easy to fit but had to remove the rear seat to tighten the 2 new bolts which cam with the kit.
The rear seat was easy to remove and required 4 bolts.
Also no modifying required.
Palethorpe01
15
18-08-2015 06:09 AM
