Van wont start T280 mwb 02plate 2litre fwd
hi im new to the forum so if its not the right area please move
i hope that this makes some sense
i have a medium wheelbase transit T280 front wheel drive 2litre 02plate van that wont start
recently i have noticed that the van seems to be running quite well when its warm but its been getting harder to stat
i noticed the other day that when i try to start it from cold the engine turns over a lot faster than it did previously and it was getting more and more dificult to start, now i am finding that the battery discharges very quickly when trying to start it .
an even bigger problem is that i went out to start it this morning and it just wouldnt go even with a jump
please HELP as i need the van for work
could be one of a few things
1 DMF (dual mass flywheel) and clutch breaking up and getting into starter motor
2 timing chain has stretched putting timing out
3 fuel pump worn pressure to low
Thanks Kev for your reply
as far as i am aware DMF has been changed out for a solid by a previous owner
possible timing chain strech as its 120k miles and as far as i am aware its never been touched
fuel pump might also be a possibility as would the fuel filter as i cant remember when the filter was last changed
What else might be causing this problem?
now that sounds like a good possibility, as its been a slow progression to spinning over faster than usual (getting worse over a week or so)
Does that mean i would be looking at head gasket problem or possibly rings ?
its a good possibility the head gasket could be at fault as i have just noticed the inside of the headder tank has a black oily coating but oil and water dont seem to be mixing either in engine or header tank
