Mk3 escort zetec conversion
1995 loom will no doubt have pats on it
at the ecu end of the loom before the big rubber grommet (inside the car) if there is an extra round pin connector thats the pats connector to the receiver ring and fuse box
the easy way is to get an ecu and loom of a pre 1994 model which does not have pats
although saying that there is a conversion to move the ecu pins about and plug a non pats ecu in
the information can be found on the web by typing in mondeo to escort ecu hack
i have a mondeo non pats ecu if you decide to go down this route
