Rear brake compensator escort turbo
Please help bleeding brakes all going ok until i get to the rear brake compensators and the fluid will not go past this point.i have even disconected arms so the internal piston is closed or open and with pressure still in (using ezebleed system) mater cylinder i cannot get fluid past them.They were defenatly working when i had them on the bench, can anyone help please
John
John
Hi John. I maybe wrong mate, but it sounds like you are bleeding them in the wrong sequence... You mystery start at the drivers rear, bleed that, then passenger rear, then drivers front, then finally passenger side. The car ideally should be on the ground do the compensaters are doing their thing (or be under tension with some tranny jacks if it's in the air). That would be my first stab as to why it's doing what it's doing. Always work from the furthest brake away from the cylinder inwards
Hi
thanks for your help a lot of the problem was the whol;e of the brake system was new and it was just a point of being patient as the fluid took so long to get to the rear plus a line full of air.
i appriciate your advise and will be a bit mor epatient nest time
thanks again
john
thanks again
john
track.focus'd
12-08-2015 05:53 PM
