2.1 zvh turbo choice help
You have few choices then, cheapest is a t34, then t38, but will have more lag but moor room for scope, or top dolla gt28, speak to who ever is doing your mapping and see wat they recommend.
why would a t34 roller bearing not be better then ?????????all round and why is a gt series turbo better than a t series converted to roller bearing just out of intrest ?and iff u was going to buy a gt series why would u not buy a gtx ?
thanks
thanks
If you had a t against gt for spool and (lag) back to back you would be hard pushed to tell the differences,
Then you got to factor in the reliability of a roller bearing, the cost of repairing it, having to water cool it and so on.
As for a gtx it's got a 11 blade billet wheel there for more moves more air.
the garret results are in the link above mate u dopnt have to water cool a t series roller bearing converted turbo !!!! you do on a gt and a t series wet floating bearing would be far less effiiceint than a roller bearing as the garret web site shows
and when i use cr turbos the cost of rebuilding a roller bearing turbo is peanutts
If boost threshold is all its about then yea carry on, but I think for the money joe blogs off the street is better off with a bogo t series,
If the op is wanting to do it on a budget and wants a really low boost target then I would be getting a frs gt25
JK12
33
26-04-2021 12:09 PM
