`2006 Fiesta 1.4 TDCI
Kingfisher
[quote=Danster76;6108770]I'm 95% sure it is next to the ecu which is front right by the battery. What fault do you have?[/quote
Difficult starting from cold, all the heater plugs are ok, they have been took out and tested.
Kingfisher
[quote=kingfisher_61;6108773]Is there a relay and a timer relay too ?, i know where the relay is mounted on the battery carrier.
glow plugs on modern day diesels are only used at sub zero temps and not like they used to be.sounds like youve got air in the system and fuel is returning back to the tank.normally the hand primer pipe assembly.does it need priming when cold to start?
Kingfisher
No, its never needed priming, its only been like this for a couple of weeks now cold weather is here, i'll try a relay and see if its any better first, thank you.
Kingfisher
Steve Escos
01-10-2015 06:57 AM
deathrider666
28-09-2015 06:12 PM
