Ford focus ST MK 2 2006.
Hi all, this is my first post but I'm hoping somebody here may have some good advice on this one.
I've just bought my dream ford, and ST mark 2.
It has a few slight problems that i know are small but quite annoying.
First up, the rear wiper does not work, the front one does so im guessing it is not a fuse. Any ideas what that could be?
number 2, the battery light is coming on occasionally usualy when I turn something like the fans or full beams on. I put a new battery in but still coming up, it is always above 12 volts on the screen so im guessing alternator, unless anybody thinks it could be something less sinister?
number 3, I had a diagnostics done and it comes up as a lamda sensor needing replacing, however its been remapped to 270BHP, so could that be whats causing the problem?
I really like this car as I do most fords, exept the KA so any advice or tips would be appreciated.
Thanks!
Joey
Thanks!
Joey
Check the aux fuse box under the glove box - there's a little map on the cover to tell you what one is for what.
The alternators are a known weak point on 06 cars - probably needs replacing.
If it's been remapped - are you sure it's not got a decat? that'd put the MIL light on if it's not a decat friendly map.
As above, get the alternator checked out first, failed ones can cause all sorts of issues. The rear wiper could be a fuse, switch or the motor itself. With the front wipers on, select reverse. Does the rear wiper then come on? What usually happens is the wiper is switched on while the blade is firmly iced on to the screen. This can pop the fuse.
Thank you all for replying.
A few of you mentioned it may be a fuse, but I was assuming that front and rear wipers would use the same fuse? However I will check it just to rule that out.
I hear what your all saying, I just got off the phone to my ford dealer, they quoted me £520 for a alternator plus fitting, I'm going just get it done and hopefully all will be well.
How would I know the difference between a decat and a remap? It's my second ST but i only had it a few weeks now and all I have is a reciept from the previous owner basically that says thanks for your custom, £200 remap. But somebody did say that could be whats causing it to give a fault code for the lamba sensor, but regardless I will follow all your advice and get the Alternator done and dusted first.
Thank you all for help, much appreciated.
