transit 2.2 tdci keeps cutting out
i have a 56 plate 2.2 tdci transit that is doing my head in
it will stall at junctions or in traffic it pulls fine higher up the revs and when driving normaly
if i stop the engine runs for a couple of seconds then the revs drop to approx 500rpm and there is no response from the throttle if i turn off the van then start it up straight away it is fine until i stop again has slowly got worse did it once or twice earlier this year but today it has done it every time i stopped
anyone else had this or any suggestions before i start throwing money at it
st170 breaking
mine (115 fwd swb 33k) has just starter knocking its arse off in low revs and surging on acceleration
i cant help with yours but we have a jumbo (68k) that will randomly stall at junctions, sometimes 50 times a say sometime not for a week
and we also have a connect (50k) that will go into limp mode for no reason too its a bit shady turning it on an off at 70 mph lol
have had similarish style faults with an old van of mine, could be accelerator pedal, find a local garage that can plug in a fault code the van, usually finds the problem, would take them 5 mins, bung them a drink, they might do it for free if they think or you let them sort the fault
Petesguitar
17
19-02-2017 12:23 PM
