Heater blower stopped working on Sierra
Does anyone know if the heater blower motor stops working on a Sierra is it likely to be the motor itself or just the switch? I seem to remember reading somewhere that if the blower stopped working it was more than likely the blower motor seizing up through inactivity...or did I imagine that?
I'm having trouble getting a switch at local breakers so if I do find a car should I go for the blower motor as well??
Anyone had this fault and can remember what it was?
Mike
Mike
take the switch out and using a voltage tester hard wire it
bypass the switch see if it comes on also under the scuttle panel
"between the bonnet and windscreen" theres plugs under a little black
pull off hood check for water inside this as it causes the contacts to
burn out "mine did this " hope this helps
jimmy oldskool
Ford Focus (All Models)
04-08-2015 06:54 PM
