Mk1 Focus Ghia TDCi heater & blower
Hi guys,
Any advice please....
The heater and blower on my Focus (2003 Ghia 1.8 TDCi 115) are both dead. The aircon also doesn't do anything but I'm less worried about this.
The display on the climate control does everything is is supposed to (numbers and symbols change, buttons light up when pressed) but nothing actually happens in terms of hot air or moving air. On any of the settings.
Blown fuse on the blower? You'd think you'd still get some heat wafting through with the temp turned right up? Cooling system is all ok.
Any ideas?
Any ideas?
Anyone?
I'm trying not be lazy - I have searched for and read a lot of similar posts here, but a couple of differences:
1. Fan not working at all, as opposed to on settings 1-3.
2. This is the Ghia with electronic temp control/blower - no reference to this in previous posts.
Thanks in advance....
Hi, did you or anyone else come up with a solution to this as my 2004 Focus Ghia has developed the same fault? Can't replace the resistor pack as there doesn't appear to be one fitted, or at least it's not located in the same footwell position as the manual selector versions?
I had the fan/air-con motor tested (by the way the resistor pack is part of the motor) and the brushes and comm were beyond repair, so a second hand unit it is then.
Hope this helps others.
Adam Graham
06-09-2015 06:04 AM
