| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Technical help Q & A Got A technical problem with you car? Keep it in here where the techies hang out and we will try to solve it for you!! |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
#2 |
![]() BANNED |
The cheapest way to get some camber is to place a washer under each lower bearing carrier and tighten, as you have drum brakes rear this would go between the back plate and arm on each wheel, just on the lower bolts so it pushes the bottom out creating some negative, but don't go mad washer thickness wise, more is not always best.
tabetha |
#3 |
Just buy a pair of camber bolts. That is the standard adjustable way.
#4 |
if thats a tried and tested method ill go down that route, cheers
| Display Modes | |
