| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Technical help Q & A Got A technical problem with you car? Keep it in here where the techies hang out and we will try to solve it for you!! |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
#2 |
They have to be electronic. Basically, a fake one. They have a throttle possition sensor that just opens the dv when you let off the throttle.
Wouldn't waste your time faffing about trying to fit one.
__________________
#3 |
you can actually fit normal dump valves to td's but as said its doesnt give any perfomance advatages its just for the noise, as a friend of mine has fitted them to his mk6 transit just for the hell of it
#4 |
do you know how to fit it,ie the wirering and pipe work ?
#5 |
#6 |
Twistin me melon man
it needs a solenoid and a switch onto the throttle mechanism, and a vac pipe linked up (i forget what else).
you have to use a twin piston dump valve or it will sound like a knat farting. if your engine is otherwise standard and sounds tractor-ish, and if your car looks blatently standard and diesel-esque, it will be daft. they sound good on a tuned up turbo-diesel with a beefy/burbley exhaust. dont be tempted to use a cheapo small dump valve. the derv doctor will do you one but its about £200-300 supply and fit. also you can rig up a switch on the dash, to the power to the throttle switch, then turn it off when you dont want it. |
| Display Modes | |
