Technical help Q & AGot A technical problem with you car? Keep it in here where the techies hang out and we will try to solve it for you!!
Welcome to Passion Ford!
Welcome to Passion Ford.
I asked a few weeks back what I would need to setup twin 40s but decided to sell them and go for the bike carbs instead. I was going to get R1 Carbs? Anybody think otherwise with what to go with? I know I need the manifold etc but is it pretty much the same needed for twin 40's? As ignition only ecu? or what do I need? Can I use Existing throttle cable? or do I have to change it etc a detailed help would be much appreciated so I can get started. Thanks again guys
If you were logged in, you wouldn't be seeing this ad! Register your free account today, or log in if you already have an account.
