| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Technical help Q & A Got A technical problem with you car? Keep it in here where the techies hang out and we will try to solve it for you!! |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
#2 |
![]() BANNED |
Unless you want a fire,(well at least it'll keep you warm!!) dispense with the ford relay and fuse for the cooling fans and rewire, the ford stuff was inadequate when new, let alone now it is so old, fuses pop due to too high a load going through them, so either the fans are drawing too much current(maybe ones seizing ?), or there may be a short on the live to fans, either way you are v lucky to haver a car left that has not been barbequed!!.
There is no link between cooling fan circuit and the blower fan for the heater, so need to look elsewhere, I'd start by checking the earth on the fan motor, then put a direct live to the motor to make sure it still works, if the above is ok look for the live at the speed switch, chances are it isn't there, so check fuses etc again. The relays by the glovebox are nothing to do with the heater fan, one is ecu feed, one is fuel pump, one is HFS, and can't remember other one, abs possibly, if there is a purple relay holder it is for air con. tabetha |
#3 |
hi tabetha
thankyou for answering my thread, sounds like i have been lucky not to have had a fire then ! i will definitely be re-wiring it all tomorrow and putting in a manual switch. i will also investigate the wiring on the heating motor & fan. thanks for the info all the best
#4 |
![]() BANNED |
There's nothing wrong with a switch if it is for OVERIDING the relay, but certainly not as the only thing that switches the fans on, as some do it that way, only takes one forgetfull moment to cost big time, so keep the std temp switch in rad to trip relay, to turn on, switch it positively, ie fan is permanently earthed the live switches, that way any overide switch(live supply) can easily be taken from a ignition switched live supply to switch then relay so you can't accidentally leave them on overide when parking up.
tabetha |
#5 |
mine was doing this and it was my fan seizing up overloading the fuse
| Display Modes | |
