PassionFord
Go Back   PassionFord > Tuning, FAQ & Post Archive's. > Technical help Q & A
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 19-03-2010, 12:49 PM   #1
keithh
Trader Score: (0)
keithh is an unknown quantity at this point
Default Ford 6000CD Loss of Sound
Hi folks, I've recently returned to Ford ownership with a 2004 Focus C-Max TDCI.
However there is a lack of sound from the Ford 6000CD radio. The radio and CD seem to function ok and if i crank the volume right up I can hear the sound but very quietly.
I have googled this and found the same problem on another site, which pointed to the problem appearing after a battery change - but no answers were given.
I picked the car up last week and suspect the battery must have been off at the dealership at some stage.
Any help would be greatly appreciated, i'm hoping there must be a simple solution to sort this niggle.
keithh is offline   Reply With Quote
Old 29-03-2010, 02:59 PM   #2
keithh
Trader Score: (0)
Bttt
Old 29-03-2010, 07:06 PM   #3
oldford
Trader Score: (0)
oldford is an unknown quantity at this point
Had this problem once on a Sierra with a separate amplifier. The fuse had blown.
Does your system have such an amplifier? All fuses (at the back) O.K.?
oldford is offline   Reply With Quote
Old 29-03-2010, 07:51 PM   #4
keithh
Trader Score: (0)
Cheers for that oldford, it sounds like a decent explanation. I will check and let you know how I get on. I'm not that familiar with the car yet but would guess it should have a seperate powered amp.
Would the blown fuse likely to be located on the rear of the unit itself?
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
