| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Technical help Q & A Got A technical problem with you car? Keep it in here where the techies hang out and we will try to solve it for you!! |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
#2 |
![]() BANNED |
I assume you tried the light dimmer switch for the dash lights ?, if the switch is duff simply fit another, or just bypass for ful brightness of the dials, most are on that all the time anyway.
tabetha |
#3 | |
Quote:
ive checked the dimmer switch and there are no wires in the back, so just thought the switch wasn't for my year, how do we bypass it? |
#4 |
![]() BANNED |
afaik, all the mondy had dimmer, it's likely as yours has the switch it does too, I would have a dig around and find the missing connector, you need this connector to easily light up the panel lights, but other ways of doing it if necessary, ie yours doesn't have the dimmer bit in the loom, so I'd defo have a good hunt for that first.
tabetha |
| Display Modes | |
