| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Technical help Q & A Got A technical problem with you car? Keep it in here where the techies hang out and we will try to solve it for you!! |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
How ye lads
#2 |
its hard to bypass, but should be fairly reelieable. make shure its an imobiliser problem for deffo. try using a different key. try jumping the starter or tow starting. the imobiliser stops cranking, also stops fuel, to bypass youl need to remove inj pump and swap the stop selonoid for a conventional type, this is not the easyist of jobs.
the fuse boxes are common to go down on these, maybe start with this. (under dash, drivers side) |
| Display Modes | |
