| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Technical help Q & A Got A technical problem with you car? Keep it in here where the techies hang out and we will try to solve it for you!! |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
#2 |
![]() BANNED |
First thing to do is check the oil level, as if not enough when hot the torque convertor gets filled, but leaves so little to operate the clutches to allow power transmission, could just be needing a bit of fluid, be VERY careful what type you put in as I think it is these that have a very peculiar ATF, and normal atf will kill it stone dead, look in handbook or phone auto trans place, if no joy with this try to nurse it to a trans place, where they'll drive it then have a much better idea of what's wrong, could be a clutch seal could be anything even the clutch drums have been known to break the fingers, but was pretty much fixed I thought on this age.
tabetha |
#3 |
these auto boxes have loadsa problems
__________________
power is nothing without control |
#4 |
![]() BANNED |
They certainly can be troublesome, most probs are due to fords shit design, in other cars that use the same box they have a draughted air design to help cool, but not in the uk.
best thing you can do even on a boggo std one is air trans fluid cooler, they are easy to fit and can be very cheap I use ones from a us car spares supplier, it's std fit on a winnibego rv of nearly 3 1/2 tons weight, same size almost as std rad, but even after long run you can touch the box as only very warm as opposed to 3rd degree burn hot!! tabetha |
#5 |
Thank you Tabetha, will try this and let you know how I get on...fingers crossed and thank you again
#6 |
![]() BANNED |
The wynns power steering stop leak stuff can work wonders in auto boxes with pressure problems, it swells the seals slightly fixed many a car for years with this stuff, might need to do it every 3-4 years but only £9!!
tabetha |
| Display Modes | |
