| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Technical help Q & A Got A technical problem with you car? Keep it in here where the techies hang out and we will try to solve it for you!! |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
#2 |
I don't much like the look of that one because it's not got the crushable sealing ring; - its just a flat piece of stainless.
I've always used these style ones effectively; - notice the ridge round the inside that the one you posted doesn't have... http://cgi.ebay.co.uk/T3-TURBO-TO-MA...item2a057115c8
__________________
#3 |
cheers for that mate
#4 |
Lord of Longridge
I've never used one. You don't need too
__________________
Cheers, Andy ![]() 11.93 1/4 mile @ 116.9mph - Santa pod Lancashire RSOC Group Chairman |
#5 |
is the seal on the metal good enuff ?
it looks like its had one on before |
#6 |
There hasn't been one originally. Nothing wrong with using one tough.
#7 |
I had to use one because the mating face on my manifold was slightly deformed. One of those gaskets with the sealing ring sorted it right out.
__________________
#8 | |
Passion for Fords!
Quote:
really? there was no gasket fitted for a good reson! when the gasket fails due to the heat, where do all the bits go? thats right, into your turbo killing the internals. face fit. skim them if they leak.
__________________
JAMES
#9 |
That's a scenario that is very hard for me to believe ever work out. Do you know of any cases where the turbine would have been killed by a Garrett exhaust gasket?
#10 |
Passion for Fords!
ive seen exhaust paste cause turbo damage years ago,
i have no doubt a fragment of gasket heading in to a turbine flat out would cause damage
__________________
JAMES
| Display Modes | |
