| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Technical help Q & A Got A technical problem with you car? Keep it in here where the techies hang out and we will try to solve it for you!! |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
__________________
BLOODY RS TURBOS !!!!!!!! |
#2 |
any one wanna help ???
__________________
#3 |
I dont see why not just have to check where engine mounts go dont know about ecu?
#4 |
done a 2ltr silver top into a p reg 1.8si was pretty much straight forward, you will need to fit the following from your 1.6, sump and oil pump pick up, water pump as the 2 ltr flows in a different direction(20 quid ish from motor factors,may as well do the timing belt kit while you`re on) you may need a 1.8 zetec clutch mind as i used the original with no problems on my si and the 1.6 may not cope, i had to change the flywheel sensor as the 2ltr one pointed a different way,but i think this was cos i used the engine from a mondy auto with a knackered box, make sure you connect all breather pipes on the back of the manifold as mine kept cutting out as i forgot about one of them, the ecu should be ok but i`d get a 1.8 from an si gti or ghia to be sure, if yours has the egr pipes in the exhaust manifold ditch it for a manifold from a 1.8 with no egr in it(some 18s have them in some dont and the egr probes protrude quite far into the exhaust ports so will free up alittle more power)good luck and make sure you refit the 1.6 cam pulley cover to make it look like a 1.6 from a quick glance
__________________
life isn`t like a box of chocolates, its likeoral sex: one slip of the tongue and you`re in deep s**t |
#5 |
p.s. if you keep the 2ltr oil pump in, use a cvh oil filter to clear the bodywork,we used a fiesta turbo one when we converted my cousins mk3
__________________
#6 |
Also you will need to swap the flywheel aswell if you are running an ib5 gearbox as the 2.0 flywheel wont fit inside the bell housing , aswell as the clutch as the mtx ones have a larger input shaft so the ib5 wont engage on the mondeo clutch plate.
some people also swap the oil pump for the escort/fiesta one as the filter comesoff at an angle to clear the chassis but i normally just fit a renault clio 1.8/2.0 16v one from a williams or similar works out to be about the same price as the oilpump gasket but without all the faff and hassle and can give more clearance than the cvh one if you think it might be a little close for your liking.
__________________
all hail the" rs turbo" Last edited by gavintwopies; 28-02-2010 at 07:12 PM. |
#7 |
cool thanks guys
i will be loking for a motor soon and starting the swap shortly after , will do a full rebuild on the 2.0 and swap the sump, pick up pipe and flywheel over when i take the 1.6 out , add a new uprated clutch and bang off she goes
__________________
#8 |
Wouldnt think you would need an uprated clutch as we have a 1.8zvh with a stage 3 head running 175bhp on a std but new mk4 escort 1.8 diesel clutch with no problems.
__________________
all hail the" rs turbo" |
| Display Modes | |
