PassionFord
Go Back   PassionFord > Tuning, FAQ & Post Archive's. > Technical help Q & A
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 12-02-2010, 02:44 PM   #1
JamesyRS
Trader Score: (3)
JamesyRS is on a distinguished road
Default Alternator Wires (Zetec)
Hey guys,
Im pretty sure both wires should be connected but all ask anyways. The main red wire is attached but I have a small blue wire hanging near by. What is this for? I know it for alternator as its been snapped off by overtightening but could this be problem being my battery dying all the time. I was going to buy a new battery today and thought Id have a look and found this little problem so if this wire is for charging then possibly wont need a battery? Thanks for any help people
__________________
JamesyRS is offline   Reply With Quote
Old 12-02-2010, 05:23 PM   #2
martysmartie
Trader Score: (1)
martysmartie will become famous soon enoughmartysmartie will become famous soon enough
Yes it does the blue wire is live when ignition is switched on (It's the return from the battery light) it excites the field windings which starts the charge process if this is disconnected there will be no output unless revved hard.
At the moment you will have no battery light and will not have any charge either.
Martin
martysmartie is offline   Reply With Quote
Old 12-02-2010, 08:20 PM   #3
Trader Score: (0)
tabetha will become famous soon enough
What he said, if it's snapped off, can you not open the rear of the alt/cover and connect a wire this way.
tabetha is offline   Reply With Quote
Old 12-02-2010, 10:12 PM   #4
JamesyRS
Trader Score: (3)
thanks guys instead of opening it up can it be soldered back onto terminal?
__________________
Old 13-02-2010, 11:13 AM   #5
martysmartie
Trader Score: (1)
If you have snapped connector rather than terminal then I would just put a small ring connector on end with a nut, I would not solder in case it damages components inside the alternator due to heat.
Martin
Old 13-02-2010, 12:10 PM   #6
Trader Score: (0)
Solder will be fine, heat will not be a problem, but with you needing to get a bolt to that temp(300C or thereabouts) any close fitting plastic will melt, this is with it off the car and opened up though, plus you will need a beefy iron to get enough heat, they don't get any hotter but can solder things thicker as they can keep up with heat needed.
As said a no no on the car really.
Old 13-02-2010, 10:55 PM   #7
JamesyRS
Trader Score: (3)
cheers guys, have a wee go at it tomorrow, got few other jobs to do too, the terminal still has a little stub so may try see if I can get a bolt and ring on but highly doubt it thanks again for help
__________________
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
