| Register | Photo Gallery | Knowledge Base | Gold & Trader Accounts | Rules | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | My Recent Topics | Garage |
| Technical help Q & A Got A technical problem with you car? Keep it in here where the techies hang out and we will try to solve it for you!! |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Display Modes |
#1 | |||||
#2 |
forgot to add the timing is right checked it twice, also has a recon starter motor, fuel pump is priming, fuel relay is working, also compression when engine is cold is ok per cylinder really need to get it started to do a proper compression test.
#3 |
It could be the cold start valve, blue plug I think around plenum area, unplug and see if it makes any difference.
Martin |
| Thread Tools | |
| Display Modes | |
