| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Technical help Q & A Got A technical problem with you car? Keep it in here where the techies hang out and we will try to solve it for you!! |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
__________________
#2 |
![]() BANNED |
Did you use MILLERS injector cleaner, this is awsome stuff and the best I've found.
What make of filter did you use ?, delphi are well worth paying extra for, it may be you are starting to suck air from a perishing filter head diaphragm, see if it is nice and solid the pumpy bit. tabetha |
#3 |
No wasn't Millers injector cleaner. Fuel filter was a Fram item. I'll check the button on top of the filter housing but i'm pretty sure it gets solid
Any other suggestions?
__________________
#4 |
![]() BANNED |
Seriously, try some MILLERS, have known it make big differences on cars already treated with other makes first.
tabetha |
#5 |
had same problem with 18 fiesta turned out to be the copper washers under the injectors run great after
#6 |
Still having problems with this. Wouldn't even start this morning. Starter motor turns and it'll fire for a second if i press the accelerator, but then cuts out
Fuel primer is solid and fuel flows from the pipe that goes to the injector pump. This is twice now that it wont start. Both after only starting the van up to move it. Seems to start ok the day after a longish drive. |
| Display Modes | |
