PassionFord
Go Back   PassionFord > Tuning, FAQ & Post Archive's. > Technical help Q & A
Welcome to Passion Ford!
Welcome to Passion Ford.
Thread Tools Display Modes
Old 08-02-2010, 06:41 PM   #1
darrenr1969
darrenr1969's Avatar
Trader Score: (1)
darrenr1969 is on a distinguished road
Default Cosworth mot emmisions ?
Hi, my 4x4 saff cosworth is going into my pals garage for its mot next week, now I know its running far too rich as the plugs are sooty black.
Question is what should I get him to set it at (to keep it safe ) as I,ve heard that running them to lean can do them damage .
And out of curiosity where are they adjusted,thanks,Darren.
darrenr1969 is offline   Reply With Quote
Old 08-02-2010, 09:27 PM   #2
forevaford
Trader Score: (1)
forevaford is on a distinguished road
screw on ecu, co screw. should be below 3% but closer 1 is achievable (non-cat)
forevaford is offline   Reply With Quote
Old 09-02-2010, 09:28 AM   #3
Trader Score: (0)
tabetha is on a distinguished road
If you are still on the old L8, as said screw, unless cat model, it depends on whose chip you have got.
Whilst lean mixes will do damage a decent map/ecu will run under 1% CO at idle perfectly, I am on greys, T34 etc, and I run 0.97% CO, PERFECTLY at idle, smoothest idle I've ever known.
tabetha is offline   Reply With Quote
Old 09-02-2010, 05:18 PM   #4
darrenr1969
Trader Score: (1)
Its a non cat car....I have no idea on the chip as I,ve posted a pic of it on here before and no one knew it.....so should I just have it set to say 1.5% or 2%
Old 09-02-2010, 05:23 PM   #5
pete mcrash
saff is working!!!...atm
pete mcrash's Avatar
Trader Score: (1)
pete mcrash
isnt he going to "globaly" adjust the whole map if he messes with the Co screw...???....not a good thing
__________________
mapped by Ahmed....set up at Grove....
Matt Lewis..01922 692424
for quality used RS parts phone Paul @ NY Spares
07759729390
pete mcrash is online now   Reply With Quote
Old 09-02-2010, 05:28 PM   #6
darrenr1969
Trader Score: (1)
No idea,but he can always put it back after the test.
Old 09-02-2010, 06:22 PM   #7
martysmartie
Trader Score: (0)
martysmartie is an unknown quantity at this point
If your car is not standard 2.5% IIRC then you need to check with the chip/author what CO should be as this effects the whole map. The screw is on ECU as said unless CAT, if you do adjust do in very small increments as is sensitive, it is known as the global mod as it subtracts fuel as a percentage which is why your supposted to check AFR/Det to make sure you are not lean up top.
Make sure car is at running temp before you check, good idea to let fans cycle then off, then check.
Martin
martysmartie is offline   Reply With Quote
Old 09-02-2010, 06:47 PM   #8
darrenr1969
Trader Score: (1)
This is the chip I have fitted ,but I,ve no idea who its from as its not in the cars history.
Old 09-02-2010, 06:51 PM   #9
darrenr1969
Trader Score: (1)
I was going to just get the car through its mot emissions and then possibly look into having it replaced with an evolution chip and having it set up so I know the fueling is safe.
Old 10-02-2010, 08:00 PM   #10
Trader Score: (0)
Quote:
Best idea, get something else in there so you know what's what.
Old 10-02-2010, 08:22 PM   #11
darrenr1969
Trader Score: (1)
Do you think the evo chip is the one to go for,. I,m still going to run the t3 with possibly siemens 55lbs injectors,3bar map and a 500 cooler.
I,m just after a quick usable car around the 300 bhp mark.
Old 10-02-2010, 09:11 PM   #12
nuttynil
nuttynil's Avatar
Trader Score: (0)
nuttynil
not hijacking the thread but some chips co was run high or overfuelled to get flames out of exhaust ..Neil i have known tuners to do this mind you i am going back 14years ago .
nuttynil is offline   Reply With Quote
Old 11-02-2010, 09:48 AM   #13
Trader Score: (0)
And some people chips are just shit put simply.
If there is nothing wrong with your present bosch injectors keep them siemens will give you no advantage, other than not needing a fitting kit.
I've flow checked 5 sets in the last two weeks 2 sets were siemens, I still see no difference doing that or in use where they are the only change.
I run 300bhp, as my bottom end has 180,000 miles on it, on a T3 machined out comp housing to take T34 trim, .48 turbine, 300@17.5psi, I am on greys and have 0.97% CO at idle with 137ppm, all the can't get good emissions with greys is just complete bullshit given by people who do not know how to map corrrectly, a statement like the above would have me running away due to thier incompetence, although I do run a K3 ecu, my idle and running is 100% perfect not a glitch in sight hot or cold idles cold with no iscv as well, can get 40mpg on a run, you cannot feel the idle it is so stable, the ca ris not adjusted down to this figure for the mot, although if needed it would only be a few taps of the keyboard, there's no need, ppm shows how clean it is running, and that's with 180,000+ miles.
Up to you what chip you want, everyone knows my thoughts, the first chip I would get would be one inside another ecu!!
NMS and MSD amongst others do perfectly good chips so won't go wrong with these two.
Old 11-02-2010, 09:58 AM   #14
R4N S S
R4N S S's Avatar
Trader Score: (1)
R4N S S is an unknown quantity at this point
when i took my car in for an MOT before I had it remapped the CO was 6.9% the mot guy nerly died of a heart attack - his face a picture
__________________
RAN
R4N S S is offline   Reply With Quote
Old 11-02-2010, 04:10 PM   #15
Trader Score: (0)
When I did a power run at emerald with someones chip after they had also set it up, it was 10.3 AFR on a light throttle, and the torque at 4500 actually dropped like a stone as the timing was backed right off!!
Old 12-02-2010, 03:45 PM   #16
darrenr1969
Trader Score: (1)
Is MSD in blackpool , and is there anywhere closer to Newcastle Upon Tyne that are reliable.
The reason I,m asking is that there is a (local) evolution chip fitter near me ,I think I got that info from the msd site...ref ;evo chips-local fitting.
Old 12-02-2010, 05:20 PM   #17
pete mcrash
Trader Score: (1)
pete mcrash
......if an MSD chip is what u want then deffo go to MSD to fit it and set up ur car aswell................there's more to chipping a car than installing the chip...........
__________________
07759729390
Old 12-02-2010, 07:09 PM   #18
Trader Score: (0)
MSD are indeed pretty much in/near blackpool, if that's the one you want might as well go there, but if you have a local place that does stus chips they will be ok, as stu wouldn't let them otherwise as it would reflect on his name, so they will be ok.
Old 13-02-2010, 03:29 PM   #19
darrenr1969
Trader Score: (1)
Thanks,guys.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Content Relevant URLs by vBSEO 3.3.0
