PassionFord
Go Back   PassionFord > Tuning, FAQ & Post Archive's. > Technical help Q & A
Welcome to Passion Ford!
Welcome to Passion Ford.
Thread Tools Display Modes
Old 07-02-2010, 09:49 PM   #1
muttsnutts89
muttsnutts89's Avatar
Trader Score: (0)
muttsnutts89 is on a distinguished road
Smile compression readings ?
hi what sort of compression figure should i have from my 89 erst 1600cvh ? a figure for a bad engine compared to say a good rebuilt one thanks.
muttsnutts89 is offline   Reply With Quote
Old 08-02-2010, 06:11 AM   #2
JesseT
Trader Score: (0)
JesseT
Equal! That is of primary importance. The value is secondary and can easily be affected by settings, such as cam timing.
On a standard engine, I'd say that the compression reading in bars should be higher than the compression ratio. On wild cams these tend to be on the same level.
__________________
Orion tic & Escort tic & 2xFocus
JesseT is offline   Reply With Quote
Old 08-02-2010, 07:21 AM   #3
rickbartlett
ford mad!!!
rickbartlett's Avatar
Trader Score: (0)
rickbartlett is on a distinguished road
i good one should be 150 psi in each cylinder
__________________
Jamsport 01604 755529
S2 IN SIG NOW SOLD AND WROTE OFF
SWAPPED SEV FOR ,BLACK RS TURBO CABRIOLET H443HOO ON 4X4 COSSIE RIMS
rickbartlett is offline   Reply With Quote
Old 08-02-2010, 08:05 PM   #4
muttsnutts89
Trader Score: (0)
the reason i ask is just done a egine rebuild on my rs. new rings, re seat valves and head skim, big and main bearings full gasket set ect.. it also has got a kent cam cvh 35 and all running great and checked the compression and i have 8.5 bar (125psi) on all clinders does this sound a little low ?? .................... regards ryan
Old 09-02-2010, 06:07 AM   #5
JesseT
Trader Score: (0)
JesseT
You will not get much higher on a CVH35. All is ok.
__________________
Old 09-02-2010, 07:24 AM   #6
rickbartlett
ford mad!!!
Trader Score: (0)
seems a little low to me
__________________
Old 09-02-2010, 10:13 AM   #7
Trader Score: (0)
tabetha is on a distinguished road
If it's a very new engine give it some time to bed the rings in properly, don't worry about the comp, just as said so long as nice and even.
tabetha is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Content Relevant URLs by vBSEO 3.3.0
