| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Technical help Q & A Got A technical problem with you car? Keep it in here where the techies hang out and we will try to solve it for you!! |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
RS Doer!!!!
__________________
Paul Roberts Last edited by paulospug; 07-02-2010 at 12:28 AM. |
#2 |
competant bodger
check around where you have welded mate and make sure you havnt melted any wires, failing that it could possibly be the light stalk
#3 | |
RS Doer!!!!
Quote:
Welding was done after the lights played up - so you think it must be the indicator stalk then? I'll take it to bits tomorrow and do some multimeter work if thats the case. Cheers, Paul
__________________
Paul Roberts |
#4 |
i think you will find it will be worn contacts inside the switch
#5 |
RS Doer!!!!
more expense then! lol
Well, what are Fords for eh? Cost you loads of money...... but we love it!!! P.
__________________
Paul Roberts |
#6 |
hi, ive got the same problem on my xr31. keeps happening. if i wobble the grey relays it comes back!! trouble is it dont stay on for long. bad connection for sure!!
#7 |
G911 TTA
my old orion had same problem,my dads xr3i has same problem rite now and my rst cab also has this problem aswell.
my mate fixed the orion by wedging the 2 relays in a different position.on my dads xr3i we changed the high beam to dipped beam wires around just so he can use it for now on back of headlights. on my cab ive had to drive it on high beam for now as i ent got round to it. ive played with the relays and doesnt make a difference.must be the contacts in fuse box. it defo wont be the switch mate
__________________
Jamsport 01604 755529 ![]() S2 IN SIG NOW WROTE OFF ![]() NOW DRIVE BMW 328i E36 CONVERTIBLE AND VAUXHALL ZAFIRA GSI TURBO FAMILY WAGON |
#8 | |
RS Doer!!!!
Quote:
I put a voltage meter onto the contacts in the fusebox with fuse out (lights on of course) and there was no power either side of it. that's what made me think it must be further back in the system Paul
__________________
Paul Roberts |
#9 |
G911 TTA
did u try the relays at the back or just the fuse for main beam?
__________________
#10 |
RS Doer!!!!
Both! lol.
Just been having another play with it now (just to make things more complicated)..... ok, ignition on, sidelights are ok. turn them onto dipped beam - the sidelights are on but only about half power so very dim and when you turn it from sidelights to dipped beam, you can hear a rely clicking. Have had the connector off the back of the switch and when I run a direct live to sidelights - they work, to the main beam - they work, then to another position (which I suspect must be the dipped beam) a relay clicks but no dipped beam! There is no power to the connectors on the back of the lights whatsoever.... I hate wiring!
__________________
Paul Roberts |
#11 |
G911 TTA
exact same problem as mine mate,and i dont know how to cure it lol
__________________
#12 |
hi mate had the same problem before on one off my escorts.
i made the mestake of putting in some of those powerfull couloured lights it burnt out one of those grey relays in the fuse box and the conectors that it pluged into!! cost me a bomb |
#13 |
Trader Score: (0)
Rep Power: 8 ![]() |
I also have the same problem.But mine take time to come on.Depending how cold it is.The colder the weather,the longer it takes for them to come on.
When they aint working,the side lights will go dim when trying the main lights. been bugging me loads lol |
#14 |
Orion ZT coming soon
Gotta be worth trying a new relay, and if your only getting half power I'd also clean the earths up on the inner wings
#15 |
check the two grey realys, they usually burn out the contacts, common problem.
#16 |
Trader Score: (0)
yeah.thanks for advice.done all earths and still same.relays are next step.
#17 |
Hi there just to say this is a common problem on mk4's load's have had same problem as it's been said the 2 relay's at the back of fuse box melt
got mine 2 come on by wiggling relay's took mine to leecy's and they moved relay out of fuse box........ lights now work no more half beam or getting out to play with relay's........
| Display Modes | |
