PassionFord
Go Back   PassionFord > Tuning, FAQ & Post Archive's. > Technical help Q & A
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 30-01-2010, 10:55 PM   #1
stuart-smalley
Trader Score: (0)
stuart-smalley is on a distinguished road
Default electrical problem with my escort van 1.8 straight diesel w reg
hi i have a 2000 w reg estcort van 1.8 straight diesel, the other day i was driving home from work and my van just cut out, the van would not turn over the dash light's was on apart from the glow plug's, got towed in and it was my number 22 fuse (20 amp), changed in and of i went, the next day it did the same, same fuse again, changed it then the next day it did it and then i noticed their was some smoke coming from the bonnet, took the positive termenal off, the fuse had gone and on further inspection their was some burnt wire's, traced the wires to the fuel pump, replaced the wire which was burnt but still nothing, checked the fuse box and it was burnt inside, put another 1 in and still nothing, cheched relays ect under fuse box all ok, got power to the fuse box from ignition, no power coming out of fuse box to the starter motor, also the glow plugs light not working. please help o'm going mad many thanks stu
stuart-smalley is offline   Reply With Quote
Old 31-01-2010, 06:04 PM   #2
AndyST
AndyST's Avatar
Trader Score: (0)
AndyST is on a distinguished road
It's a while since I worked on one mate but just check the loom that runs near the top (or bottom) of the rad (all the way along) seems to ring a bell as being a problem area.
AndyST is offline   Reply With Quote
Old 01-02-2010, 06:59 AM   #3
stuart-smalley
Trader Score: (0)
thanks andy, had a look they all seem fine mate, i've looked into it further and i have a passive anti theft system on it, do you know haw to reset it or anyone else know how to reset it?!
Old 01-02-2010, 10:12 AM   #4
AndyST
AndyST's Avatar
Trader Score: (0)
Is F22 blown again? It's for the starter relay, and glow plug relay (which is more suspect and situated on the n/s inner wing), have a look to see if its got water ingress and/or burnt out.
Old 04-02-2010, 10:42 PM   #5
stuart-smalley
Trader Score: (0)
no fuse 22 ok, but the light below the clock is not flashing and i think that has something to do with the passive anti theft system, any idea's?!
Old 05-02-2010, 09:41 AM   #6
AndyST
AndyST's Avatar
Trader Score: (0)
Did you have a look at the glow-plug relay as above?
Old 06-02-2010, 10:26 AM   #7
stuart-smalley
Trader Score: (0)
yes mate seem's fine
Old 06-02-2010, 10:49 AM   #8
AndyST
AndyST's Avatar
Trader Score: (0)
Is the 50A fuse at the battery ok? Also F1 (30A) and F8 (7.5A) also check these are live.
Old 11-04-2011, 03:31 PM   #9
pantxxxx
Trader Score: (0)
pantxxxx is on a distinguished road
just wanted to say that i had the same problem, engine cut out and fuse 22 kept blowing!!!!
It was the wiring loom as AndyST says.
at the top of the radiator under the slam pannel, right next to the air intake plastic pipe there was a metal retaining clip that had worn through 3 wires causing a short.. take the air intake out to get better access.
Thankyou to all the posters above for your much needed help.
chris
pantxxxx is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
