| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Technical help Q & A Got A technical problem with you car? Keep it in here where the techies hang out and we will try to solve it for you!! |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
Has a large member
__________________
![]() 2012 white Merc C250 CDI Sport E46 M3 vert Mk2 Lotus Cortina 2.0 zetec |
#2 |
shit happens
tbh it sounds as though u need a new clutch, i take it the cable tensioner aint fucked an clickin every time u press the peddle?
__________________
#3 |
Has a large member
If the clutch was knackered the bite would be right at the top, not at the bottom of peddle?
Nah its smooth when I press the peddle.
__________________
#4 |
shit happens
it would only be at the top if the friction plate was worn but if the pressure plate was knackered it would struggle to bite
__________________
#5 |
Has a large member
Doh! you may be right. dont wanna start raising the peddle for more bite if its actually the clutch at fault
__________________
#6 |
Before the gearbox gets ripped out, just check nothing's bent or split from the pedal down to the arm, also the plastic bushes in the gearbox where the shaft goes down aren't worn or missing. I've had a release arm cracked before now, it felt like the clutch was working ok but it was actually bending the arm instead of disengaging the pressure plate. Get someone to work the clutch while you check.
#7 |
Has a large member
Yeh ive had a release arm crack and bend before. but it was easily replaces cuz it was bolted on/clamped on one. but on this box its welded on so not sure how to replace the arm? we did compare it to my fezzy and my mates rs turbo and it does look like the arm should be further back.
__________________
#8 |
Has a large member
So does anyone know how you can replace the arms when there the weld on ones?
__________________
#9 |
The arm may appear to be further back only because the pressure plate is worn and the ratchet has taken up the slack mate. Looks like you'll have to bite the bullet and take the box off to investigate
#10 |
G911 TTA
i had same peoblem with an old rs,literally exactly same poblem.got jamsport to chop sumat out of peddle to raise it up slightly and cured problem.id rather try this before ripping box out
__________________
Jamsport 01604 755529 ![]() S2 IN SIG NOW WROTE OFF ![]() NOW DRIVE BMW 328i E36 CONVERTIBLE AND VAUXHALL ZAFIRA GSI TURBO FAMILY WAGON |
| Display Modes | |
