| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Technical help Q & A Got A technical problem with you car? Keep it in here where the techies hang out and we will try to solve it for you!! |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
#2 |
You can find a lot of info here: http://www.siipicossu.com/manuaaleja/manuaalit.htm
#3 |
![]() BANNED |
It's very basic wiring and has been covered many many times on pf, just do a search.
As you've discovered it is a chronic weak point on the cossie, at least you found out before a blown gasket!! tabetha |
#4 |
As said common issue as is the fuel pump wiring, you need to rewire direct from battery. Basically the looms were substandard to start with and now with age are worse and can not cope with the power demand the components need, the fan one melts from the fans staying on for to long and melting the fuse/relay. Do a search and theres diagrams etc showing exactly what to do.
Martin |
#5 |
Can any one tell me whot to search for as iv tried an found nothing thanks. a pdf file would be brill thanks
#6 | |
Quote:
![]() There not all cos-worth links but the infos there for you http://passionford.com/forum/search....archid=2423039 hears a PDF file on how to keep the car reliable as well http://www.motorsport-developments.c...AF257.tech.pdf
__________________
I'm Only Happy When It Rains PC Bang tidy this link http://www.hiren.info/pages/bootcd http://www.frost.co.uk/automotive-bodywork.html Last edited by avid-fan; 18-01-2010 at 10:46 PM. |
#7 |
Thanks alot people youv all been a massive help thanks alot an hope i cure this fault
| Display Modes | |
