PassionFord
Go Back   PassionFord > Tuning, FAQ & Post Archive's. > Technical help Q & A
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 12-01-2010, 06:40 PM   #1
24vcossiemat
no more Granada's for me
24vcossiemat's Avatar
Trader Score: (0)
24vcossiemat is on a distinguished road
supramat2000 Matthew mitchell
Default clio 1.5dci annoying starting problem HELP!!!! this is getting to be a pain in the !
my sister has had an ongoing problem with her 51 plate clio 1.5 diesel.. quite often she gets in it and its wont go.. the immobiliser light stays on and the glowplug light doesn't come on when you put the ignition on.. yet if you go to it a couple of hours later it starts fine.. she has put a brand new battery on it.. had a new key and decoder ring by renault and it still keeps doing this.. yet when it does start its first turn of the key. its getting on her tits now cus renault don't seem to want to know anymore, so do you know anyone that has had this problem or can shed some light on it..
just so you know, it can't be glow plugs cus when it does start its first turn of the key, had battery and new key plus decoder ring.
to give you an idea how much this is winding her up, she has called the breakdown people out 20 odd times in the last year to get towed home.
one idea that has been put too me.. her sunroof leaks like a siv, and apparently there is a immobiliser sensor next to the interior light that could be getting damp, have you heard of this???
__________________
24vcossiemat is offline   Reply With Quote
Old 12-01-2010, 06:45 PM   #2
24vcossiemat
Trader Score: (0)
anyone??
__________________
Old 12-01-2010, 06:51 PM   #3
as355f1
Working or sleeping
as355f1's Avatar
Trader Score: (0)
as355f1 is an unknown quantity at this point
very common for crankshaft position sensors and also the ecu plug is shrouded with a metal security jacket, this jacket rubs through the loom and causes all sorts of bother, we just remove them and throw it in the bin whenever one comes in.
as355f1 is offline   Reply With Quote
Old 12-01-2010, 06:54 PM   #4
24vcossiemat
Trader Score: (0)
Quote:
what, when one has this problem or something else??
__________________
Old 12-01-2010, 06:58 PM   #5
as355f1
Working or sleeping
as355f1's Avatar
Trader Score: (0)
crank sensor usually keeps the immobilizer light on and stops it starting
Old 12-01-2010, 07:00 PM   #6
as355f1
Working or sleeping
as355f1's Avatar
Trader Score: (0)
oh and check the earth wire to the ecu and check the fuse box in front of the battery for corrosion, the relays are under the fuses
Old 12-01-2010, 07:01 PM   #7
24vcossiemat
Trader Score: (0)
cheers for that mate, i'll see what the others say an if there's a few saying that then i'll tell her. would the glow plug relay cause it or not
__________________
Old 12-01-2010, 07:09 PM   #8
as355f1
Working or sleeping
as355f1's Avatar
Trader Score: (0)
i would have thought the dealers would have tested for power to the glow plugs, to be honest even if they were off it would still try to start, does it start with a tow ?
Old 12-01-2010, 07:18 PM   #9
24vcossiemat
Trader Score: (0)
haven't tried it mate to be honest
__________________
Old 12-01-2010, 08:07 PM   #10
24vcossiemat
Trader Score: (0)
have just found out, if ya disconnect the battery an put it back on it starts
__________________
Old 14-03-2011, 11:41 PM   #11
willie b14
Trader Score: (0)
willie b14 is an unknown quantity at this point
i thought the same about nothing to do with the heater plugs, found out if theyre not working the car wont start i had the exact same problem, theres 2 relays for the plugs, the wee one was dirty and not making a connection so i cleaned it up put it back in and av not had a problem since.
willie b14 is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
