| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Technical help Q & A Got A technical problem with you car? Keep it in here where the techies hang out and we will try to solve it for you!! |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
can you smell purple?
Trader Score: (0)
Location: normally dewsbury west yorkshire, but i could wake up anywhere!
Rep Power: 3 ![]() |
__________________
DIESEL POWER "if there's no smoke, there's no poke"
#2 |
unfortunately the pump will have to come off again, they are coded to the ecu. but u can get away with swappin the electronic gubins over and use the ones from the original pump, but u will have to tap the shere bolts out with a centre punch and hammer as their is armoured metal tamper proof plate around them. Iv been their and done that wot uv done.
#3 | |
Trader Score: (0)
Quote:
aaaaarrrrrraaaaaaaaggggggghhhhhhh
__________________
#4 |
on my 306 td i had the same problem the pump was coded and it wouldnt start because the immobilizer was in the key, a way round it was to run a live of the ignition to the stop solenoid on the pump, not sure if its the same as a escort/mondeo but work a try
| Display Modes | |
