PassionFord
Go Back   PassionFord > Tuning, FAQ & Post Archive's. > Technical help Q & A
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 06-01-2010, 05:32 PM   #1
Matt Tenpenny
also known as mini idiot
Matt Tenpenny's Avatar
Trader Score: (0)
Matt Tenpenny is an unknown quantity at this point
Default mk5 fiesta 1.25 misfire
hi, at 1st the fiesta would have a intermittant misfire when cold but then as it got warm it would disapear.just lately its got worse,even when hot.
now it does it perminantly now. now i am quite good with mechanics but this has me totally confused.com
there is no sign of head gasket damage
ive changed the plugs
ive tryed different leads
coil works as i get a spark when the spark plug is removed and earthed on something metal
The misfire is coming from number 4 pot and its doesnt get any better or worse with the ht lead removed.
tottally flumuxed.
any help would be gladly recieved as my local ford thieves sorry dealers want £80 for a diagnostic.
Matt Tenpenny is offline   Reply With Quote
Old 06-01-2010, 05:35 PM   #2
clarke5700
YES I KNOW I CANT SPELL
clarke5700's Avatar
Trader Score: (0)
clarke5700 is on a distinguished road
Send a message via MSN to clarke5700
have you tryed a compression test? or swaping the injector out of the problem cilinder for one of a good cilinder? to see if the problem changes to a different cilinder?
__________________
" im special,, excuse my spellings"
clarke5700 is offline   Reply With Quote
Old 06-01-2010, 05:39 PM   #3
Matt Tenpenny
Trader Score: (0)
its not the injector as the spark plug gets sooted up and it stinks of unburnt fuel.
but i havent tryed a compression test.
Old 06-01-2010, 08:25 PM   #4
Lloyd
escort mk4 cossy 4x4
Lloyd's Avatar
Trader Score: (0)
Lloyd is an unknown quantity at this point
coil pack is a common problem. even if its sparking to earth,when its in the cylinder under pressure,it wont work.
ps, 80 quid diagnostic,could be cheaper than randomly replacing parts,hoping to cure a problem
__________________
Lloyd is offline   Reply With Quote
Old 06-01-2010, 08:33 PM   #5
Ginger Will
Ginger Will's Avatar
Trader Score: (0)
Ginger Will is an unknown quantity at this point
There was a thread about this the other day and I'm sure someone said you can use a Zetec coil pack of a focus 1.8 or 2.0? I'll see if I can find the thread...
http://passionford.com/forum/ford-fo...r-misfire.html
admittedly a Focus, but its the same basic engine I think?
Ginger Will is offline   Reply With Quote
Old 06-01-2010, 09:39 PM   #6
Matt Tenpenny
Trader Score: (0)
well after me and my dad had a chat about the problem i remebered that when the radio is on i get interference in the way off a small clicking noise,not when the cd is on,just the radio.
my dad said go and watch the leads with it running while its dark,move them around and tell me what you see.
well upon doing this i discovered that the leads are very slightly arcing across each other and onto the rocker cover.
when you rev the car the flashes and tiny sparkes get brighter.
so im going to buy a brand new set of leads.
i also discovered that spraying wd40 on the leads stopped this for a very short time.
watch this space to see if the new leads work tomorrow!
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
