| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Technical help Q & A Got A technical problem with you car? Keep it in here where the techies hang out and we will try to solve it for you!! |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
#2 |
![]() BANNED |
The first problem points to air getting in the fuel line, look for leaks, esp around the fuel filter.
The water valve is indeed the likely culprit, just follow the heater pipes through the bulkhead, you will soon see it, I think they have 4 pipes going to/from it, for now I would just jam the thing open if you can, they also suffer from blown pcb's, not sure if the heater on yours is fitted with these though. tabetha |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Escort Mk5 Cab problems | Jamiepc | Technical help Q & A | 3 | 15-03-2009 04:24 PM |
| Escort mk6 cabriolet on escort cosworth alloys lowering problems | McGoo 69 | Ford Escort RS2000 Mk5 & 6 | 1 | 29-12-2008 08:00 PM |
| mk3 escort problems | andre_k | General Car Related Discussion. | 3 | 29-05-2008 08:49 PM |
| ESCORT LX 1.6 problems | starfish | Technical help Q & A | 4 | 25-12-2006 05:35 AM |
| escort mk3 escort se cabriolet running problems (wont run) | S1 JOHN | General Car Related Discussion. | 7 | 23-08-2005 01:51 PM |
