PassionFord
Go Back   PassionFord > Tuning, FAQ & Post Archive's. > Technical help Q & A
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 25-12-2009, 01:06 PM   #1
jakemuk
Trader Score: (0)
jakemuk is on a distinguished road
Default alternator belt for escort van , how to tighten
my alternator belt is squealing on the van, has happened for a day or so since its been proper cold i realy need to tighten it up as its proper dammed annoying,
Can anyone tell me how to do it, obviously no garages open today, And also i will have to park the van one side on a curb as i have no axle stands / ramps
jakemuk is offline   Reply With Quote
Old 25-12-2009, 11:58 PM   #2
rstdave
Trader Score: (3)
rstdave is an unknown quantity at this point
Undo the bolt on the alternator bracket that tensions it......get a pry bar or similar implement and apply more tension on the belt.....tighten up, and job done. It may also squeel if you properly overtighten it so just give it a go and see how you get on, very simple job. May be helpful to have another person tighten up the bolt when you tension the belt.
__________________
RS Turbo being broken......Focus RS now here!!!
rstdave is offline   Reply With Quote
Old 27-12-2009, 02:13 PM   #3
Trader Score: (0)
tabetha will become famous soon enough
As above but depending on the year of the van some have a "geared" arrangement on the adjuster which you simply turn after loosening the locknut, turn to tension then tighten locknut, looking for around 1/2" deflection on the longest run.
tabetha is offline   Reply With Quote
Old 03-07-2010, 08:37 AM   #4
pantxxxx
Trader Score: (0)
pantxxxx is on a distinguished road
hi, has anyone got a rough diagram of which way the belt goes round? please.
pantxxxx is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Tighten up your belt then! Pf Admin General Car Related Discussion. 68 02-09-2008 10:49 AM
Alternator belt krisberic Ford Sierra / Sapphire / RS500 Cosworth 4 28-03-2007 05:19 PM
CVH alternator belt haz87 General Car Related Discussion. 2 17-10-2006 07:39 PM
ADJ ALTERNATOR BELT?? COSSIE 1 Ford Escort RS Turbo 3 29-01-2006 04:38 PM
Alternator Belt.... SapphyMike General Car Related Discussion. 2 24-09-2004 03:36 PM
