PassionFord
Go Back   PassionFord > Tuning, FAQ & Post Archive's. > Technical help Q & A
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 22-12-2009, 09:05 PM   #1
cozi500
cozi500's Avatar
Trader Score: (0)
cozi500 is on a distinguished road
Question Mk2 Escort rear axle bearing removal
Anyone know where i can purchase a axle bearing puller to remove the bearings, i have removed the diff shafts, and the bearing sits at the back of the hub, the hub is a fixed type on the shaft so the bearing has got to be pulled from the shaft side, i cant find a puller long enough to pull the bear from the shaft. Any suggestions please or tooling i could use.
cozi500 is offline   Reply With Quote
Old 22-12-2009, 09:34 PM   #2
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
Trader Score: (0)
ajamesc is on a distinguished road
Default bearings
Quote:
if your replaceing the bearings then a bit of heat and too leaver bars will get them off
__________________
ajamesc is offline   Reply With Quote
Old 22-12-2009, 09:35 PM   #3
mallspeed
Trader Score: (0)
mallspeed is on a distinguished road
i use a slid hammer to get my halfshafts out with the bearing on the shafts then cut the bearing off and drop a new one on
mallspeed is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
l reg escort van rear bearing removal LEV204 Technical help Q & A 1 01-11-2009 02:11 PM
2wd rear axle removal fluxysaph Technical help Q & A 2 26-10-2009 08:13 PM
Rear Bearing sutck on Axle. dunketh Ford Escort RS Turbo 7 03-07-2008 11:12 AM
REAR AXLE REMOVAL cos jon General Car Related Discussion. 1 06-04-2006 08:32 PM
spigot bearing and rear oil seal removal (cos) B11GNS General Car Related Discussion. 4 08-10-2004 05:59 PM
