| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Technical help Q & A Got A technical problem with you car? Keep it in here where the techies hang out and we will try to solve it for you!! |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
#2 |
escort mk4 cossy 4x4
doesnt this engine have a immobilizer fitted? does the red light by the clock come on?go off when the key is in the ign pos?
__________________
#3 |
yes it comes on flashes faster then it used to and keeps flashing, ive only ever had one key for it.
#4 |
__________________
#5 |
ok what is iirc? and is there a quick fix for this?
#6 |
iirc = if i remember correctly.
turn the ign on,led flashes for about a min,then it goes into fault code reading.i/e 1 flash pause 3 flashes = fault code 13 or 1 flash pause 5 flashes = fault code 15 find out what yours are,and post them up.
__________________
#7 |
rite ive counted, flashes 3 times, pause the n flashes a further 2 times
#8 |
code 32 is the evp sensor.part of the egr system.exhaust gas recirculation.
i dont think that would stop the engine from starting. i think the problem is that the fuel pump has a imobilizer fitted,and you need to swap the imobilizer over from the old unit.its behind a tamper proof cover.
__________________
#9 |
ok thanks ill try that, im guessing if its tamper proof thats going to be no easy task
#10 |
rite, that seems to have worked but now theres a new problem, no fuel was getting through, so i rigged up a clear filter and fuel lines, sucked up some fuel to make sure of no blockage but now the fuel is not getting pulled into engine, does it need blleding and if so where is the bleed valve on the escort pump?
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Turning Engine management light off in mk6 fiesta? | Coldo | General Car Related Discussion. | 1 | 11-08-2006 07:06 PM |
| fiesta courier Q | cossiegreg1 | General Car Related Discussion. | 6 | 12-05-2006 04:11 PM |
| fiesta courier Q | cossiegreg1 | Technical help Q & A | 2 | 11-05-2006 05:28 PM |
| fiesta courier Q | cossiegreg1 | Technical help Q & A | 1 | 09-01-2006 09:43 PM |
| Fiesta 96 Courier J5S | yoda | Ford Fiesta Rs1800 & Rs Turbo | 0 | 19-04-2005 11:10 AM |
