ragtop noise..
ps3 name.. LYNX-79
ragtop noise..
me mk4 cabbys grand.. but theres a lot of wind noise off the roof when its up.. theres no tears in it.. jus wondering if anyone had ideas of how to reduce it.. i thought about building a small lip with filler on the top of window screen beam to reduce air whistling down that front join.. but i think the worse place is the join on the rear side windows.. jus a thought is all...
the side glass is a common problem with cabbies..ive fitted a good few and no matter how much i tried adjusting the window there is always a slight noise..ive seen it a few times where the glass was as close as possible, then the roof dropped the gap was bigger..as if the roof didnt settle in the same position twice.. may be something you might have to just put up with..try adjusting the glass though, chances are you will get it a bit better at least
Ragtop
17-11-2004 12:48 AM
Ragtop
27
25-07-2004 12:15 PM
Ragtop
14
13-04-2004 02:42 PM
