PassionFord
Go Back   PassionFord > Tuning, FAQ & Post Archive's. > Technical help Q & A
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 25-11-2009, 06:54 PM   #1
zetecdan
Trader Score: (0)
zetecdan is an unknown quantity at this point
Default alternator wiring..... focus and mondeo
i have fitted a smaller focus alternator to my mondeo as the mondy one fouled the supercharger inlet manifold. the charge light on the dash no longer works bulb is ok and the battery is charging fine. as i understand it the focus one is ecu controlled where as the mondeo one isnt so is there a way to get the dash lamp working. the mondeo plug fitted straight onto the focus alternator btw with no mods etc
__________________
Supercharged mondeo
zetecdan is offline   Reply With Quote
Old 26-11-2009, 04:36 PM   #2
Trader Score: (0)
tabetha will become famous soon enough
I thought the mondy were all ecu controlled, I can't see why it would be any different control wise.
I'll do some digging for you.
tabetha is offline   Reply With Quote
Old 26-11-2009, 06:30 PM   #3
zetecdan
Trader Score: (0)
thank you tabetha, will check back later
__________________
Supercharged mondeo
Old 26-11-2009, 08:28 PM   #4
cabriolet
Trader Score: (0)
cabriolet is an unknown quantity at this point
fella give me numbers from both alts i can then give u a definite answer some mondys were wired normally some the same as a focus
cabriolet is offline   Reply With Quote
Old 30-11-2009, 08:18 PM   #5
zetecdan
Trader Score: (0)
there are several numbers on the mondy alternator (bosch) which are....
0 124 415 006
KCB2 14v 57-105A
98BB 10300 BE
the focus ones arent visible while its on the engine and i dont want to pull the supercharger to get access.
__________________
Supercharged mondeo
Old 05-12-2009, 09:07 PM   #6
cabriolet
Trader Score: (0)
been away fella just read this that set of numbers are not for a smart charge alternator think the pins are [w 7 volt output][sense 12 volt input] [l warning light] a rebuilder may be able to help u the focus alternator is running at its default setting 55 amps all the time
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Alternator wiring. Need help please! Recogniseman Technical help Q & A 4 22-04-2009 06:26 PM
Alternator Wiring Help siward Technical help Q & A 2 23-08-2008 08:25 AM
Alternator Wiring ProjectBobcat Ford Sierra / Sapphire / RS500 Cosworth 3 21-04-2007 06:17 PM
alternator wiring help please The Sludge General Car Related Discussion. 13 28-03-2006 06:43 PM
Alternator wiring help. Lincolndanny Ford Escort RS Turbo 1 10-11-2005 06:46 PM
