ST170 ABS Light
Old 25-11-2009, 09:27 AM
dazz25
dazz25's Avatar
Default ST170 ABS Light
Hi all,
I have a 2002 ST170.
Driving to work yesterday and the ABS and traction control lights came on. The car is driving fine but the lights won't go out!
Does anybody have any ideas of what the problem could be or suggest anything that I should check first?
Old 25-11-2009, 10:12 AM
davek1
davek1's Avatar
check the fuse's in the glove box mine did the same thing but cant remember what fuse it was
Old 25-11-2009, 10:15 AM
MarksST170
MarksST170's Avatar
I would try the fuse first and then try and see if the brakes are still using the ABS safely. Then maybe try cleaning the brake sensors as this is what my mates was all covered in dirt sprayed with brake cleaner and it went off never came back on. It could be something else but these aren't going to cost you anything
Old 25-11-2009, 03:45 PM
dazz25
dazz25's Avatar
Great advice guys. Thnaks for your replies!
I'll check the fuses tonight and give them a clean at the weekend if that doesn't work.
I was hoping it might be a drity sensor but never thought about checking the fuses!
Old 25-11-2009, 04:55 PM
andy milligan
newbe
andy milligan's Avatar
you can pull some codes up on the dash to give you some idea of problems however not all DTC's are shown on the dash.
Try www.ffoc.co.uk for info on how to do as can never remember.
Old 28-11-2009, 02:05 PM
STbash
STbash's Avatar
fuses be my guess, for 2 years of ownership mine had the Light on, i did remove the fuses though.. hate driver aids
155lee
06-09-2016 11:10 AM
Dr. Ickxs
15-09-2015 10:15 PM
The Enigma
12-09-2015 10:12 PM
morg65
Escort MK 5 / MK 6
11-09-2015 01:55 PM
fuzzy
04-09-2015 10:11 PM
Quick Reply: ST170 ABS Light
