water in both footwells escort van
Old 22-11-2009, 09:33 PM
jakemuk
jakemuk's Avatar
Default water in both footwells escort van
Hi All,
when it has been raining i always end up with a bit of water in the vans footwells, Not a major ammount but annoying,
Any tips of where to look ?
Old 23-11-2009, 11:45 AM
jakemuk
jakemuk's Avatar
well as an update, I thought i would check to see if there was any crap where the water drains out, As i remember having been to a car wash once and saw all soap and water still down there, There was aload of leaves and mud, I have ripped all that out down the drivers side, When i was in there i noticed there was a hole into the wing with a main wiring loom run through it, Quite a large hole, Should that have a grommet in ?,
Also where are all the drains and what do they look like, So i can clear it all out and make sure there running free, As i have a feeling if there like the bit itself it will be all crapped up.
Also how do you clean em ?
Old 23-11-2009, 12:01 PM
Yes there should be a grommet anywhere the bulkhead has a hole, what age is the van, on the escort vans battery tray rot is common and leads to floods.
Old 23-11-2009, 12:20 PM
zetec-Sam
neeeeeeeeooowmmmm
zetec-Sam's Avatar
door seals? our landy fills with water when it rains cos both doors dont seal prooperly
Old 23-11-2009, 12:58 PM
jakemuk
jakemuk's Avatar
Its a T Reg Van tabetha,
Will inspect the door seals, And i think that that hole in the drivers side wing, Where the main loom goes is the culprit, I will get to the scrappys and get all the grommets and fit them in, See if that cures the problem, Also need to find out where the drain holes are and to clean them out ?
Vincereese
01-06-2023 09:14 AM
FlashRS
14-09-2015 12:36 PM
Mxkid
31-08-2015 10:02 PM
Vincereese
18-08-2015 03:57 PM
Vincereese
16-08-2015 06:38 PM
Quick Reply: water in both footwells escort van
